if u know a machinist ask him for a tube that the end mills come in. the rubber caps on the ends of the tubes work great. 5/16 endmill case by the way.
If it is like a lot of the other Kawaski speedo hubs, if you look at it closely you can see that it is a multipiece unit. You can actually knock the center out of the unit and it makes a perfect spacer.
