Recently the intake side piston skirt shattered, and there are still a bunch of small pieces stuck down in the crank cavity. So far I have gotten the cylinder off, tranny out, right cover off and guts out, magneto pulled, and the case bolts out.
Question is, what is the PROPER way to actually split the cases? I can get the seams to open up a little bit (had to torch the seams a bit) but I cant seem to get it all to come apart at once. I think one of my problems is with the crank area. I can't get the top and bottom parts of the cases to spread apart equally...I can tell because the crank won't rotate at all when i start to spread this area.
Please, any tips are very much appreciated!!!! :)
