Here is one for you. For instance lets say on a new KDX 200. If one used a 40kg spring with 10mm preload vs. a 39kg spring with 20mm preload(ie. stock spacer on KDX).... what would be the actual difference? You see what I'm asking? Which setup would end up being "stiffer" or "plusher"? Just how does this work out in technical terms? Lighter spring-more preload or slightly heavier spring with less preload?
