i am a 12st clubman enduro/h&h rider. What spring rate should i use in the front fork of my 03 220
M mattt Member Apr 13, 2003 2 0 Jun 5, 2003 #1 i am a 12st clubman enduro/h&h rider. What spring rate should i use in the front fork of my 03 220
C canyncarvr ~SPONSOR~ Oct 14, 1999 4,005 0 Jun 5, 2003 #3 Emphasis on guess. The spring rate that is 'correct' for you has a lot to do with your riding style, ability and what kind of ride you want. Racetech has a spring rate generator. Run your numbers through it, subtract two sizes and you'd be close. Jeremy (mx-tech) has a spring rate generator, too, I believe. Give it a shot. Is being a 12st clubman (whatever that is) of import in spring rate choice? That wouldn't by chance be '1/2 fast' would it? ;)
David Trustrum ~SPONSOR~ Jan 25, 2001 1,396 0 Jun 6, 2003 #4 Isn’t 'stone' (st) part of the archaic measuring system you guys use? Like 14 pounds to a stone, 12.7 tons to an inch, 19/64 feet to a Fahrenheit? 4000 cubits per fathom or something? That would make him a tickle under 170 pounds or ~ 76kg in real money. ;) Hot setup is take the fork caps off & pour oil in till they’re full. Friday night here, I’m off for a beer.
C canyncarvr ~SPONSOR~ Oct 14, 1999 4,005 0 Jun 6, 2003 #6 Yeah...summa those .38 XR springs I'm hearin' about all the time would be about right! Or the .40s if you're if you're a bit faster stoner! ;)
