Dan B.
8
I put a 52t rear sprocket on my YZ250f and it seems like the chain is too short. I have the wheel all the way up on the adjusters and it appears to be short by few inches. It is a stock chain (111 links + master link about 71"long). Is this a typical problem? Do I have to buy a new chain and if so what length do aftermarket chains come?
Glitch
630
You can buy chains up to about 120 links I think. Then you can put it on the bike with the new sprockets and mark how many links you must remove. Then use a chain breaker, or grind away tapered part of pin but not suggested, and then you have a chain that fits, and you can take the rest of links and make them into a sweet key chain.
woods_rider1
355
chains come in many different lengths according to what you need. When you buy them, you will see a number like 116, 118, 120 etc, this is the # of links. If you went to a larger sprocket, you will need to get a longer than stock chain.
If your chain is in good condition, you can add a extra link or two and run two master links. Not a big deal. :thumb:
