jimt_yz400
- Dec 25, 2000
- 314
- 0
I have this strange problem that I haven't been able to figure out.
I hope that someone has run into this or has some advice.
The other day I jumped on my sons CR250 to help out of a situation and I noticed that the forks were very stiff, I mean really stiff. I took them apart and I replaced the leaking fork seal and all bushings. I changed the cartridge fluid and outside chamber fliud.
I did notice that one of the fork upper leg did not want slide down on the down tube as easy as the other (this is w/o and cartridege, oil or anything else). I then had the down tubes checked for trueness and they were verified that there were fine. I even had a suspension tuner polish everything for me.
Ok, when the forks are installed on the bike they are very stiff, definitley some binding going on. I have loosened the clamp bolts and the axel but to no avail. Even with .38 springs in them they are stiffer than my bike (same bike and year) with .42's.
I have torn these things apart about a dozen times and I have brought them to a tuner but when they are on the bike something is wrong. They feel only OK off the bike but not as buttery smooth as other forks I have worked on.
Any ideas?
I'm thinking of buying an entire new set from Service Honda the $1100 but I would rather try to fix these things!!
Thx!!
Any ideas?
Thx!!
