I am not sure if a stiffer spring would help with head shake or not. But I think you should be running more sag.My 125 had bad head shake till I set my sag at 115mm. You should should try more sag first this is easy and costs nothing.If you go on the Mxtech website you can use there spring generator to find out which fork spring is right for your weight.
