I've been having problems starting since putting this new pick-up coil on my 1995 kx250. The other day when I first installed it the bike would start, just, but wouldn't run above idling speeds. The kickstart kept on kicking back up every now and again too :yikes: I adjusted the pickup coil gap yesterday to 6 thousenths of an inch, retarded the ignition timing, via the stator plate, so now the marks are aligned in the centre and now it won't even start! We tried bumping it down a hill and it fired for a split second then died out. We took the plug out and it was oily, but the plug was new in when we first put the pick-up coil in as I mentioned above. I cleaned the oily residue off the plug and checked for a spark, it has a nice fat blue spark across the gaps which I presume is fine? So what do you guys think, carb problems? I readjusted the float level yesterday as it was too high. The only thing that I can think of with it being a fuel problem is that the bike had been sat in the shed for a month or so with fuel in the tank and carb, would this gack everything up, like the reeds?
Help! :( :bang:
Help! :( :bang:
