So I just finished adding the FMF pipe, Boyesen reeds and airbox mods. Will the stock clutch be okay for a while or will it be toasted right away? (05' 220)
Cool. I would rather spend the $$ on new tires and a steering damper. I am used to an XR 600 and a KTM 300 so I don't much care for over using the clutch. I did leave the pilot stock at 42, raised the clip on the needle from 3rd to 2nd position from the top and bumped the main up from 145 to a 148. I have'nt been able to check it out yet because it is 10 below zero and we have a foot of snow on the ground here. How does this jetting sound?
