Fred T
5,272
Based on the information you gave us I can tell you that your bike came with a pilot jet, main jet and needle jet stock. :uh:
gooleo
i think he has a '02 200. i read a thread a few days ago and saw that. i have the same bike so i remembered an compared mods.
Fred T
5,272
If this is true then you have 42 pilot, 145 mian and r1173 needle.
Std jetting with airbox lid mod and new pipe is leave main and pilot alone, move needle down one notch (raise clip) and ride. YMMV in different altitudes and temperatures. I personally think the stock needle is a little lean and recommend a CEL with stock carb.
23jayhawk
675
I believe our local Factory rider  :worship:  has given you the setup on a '02 220R. If you have the 200, it likely came with 160M, 48P, and R1174K needle in #3 clip.
canyncarvr
4,005
Ha! Orange is making you s-l-o-w, fred!!
What 23jay said! Note the 'likely' part. Dealers have been known to change things even on new bikes!! What jay lists is indeed the oem spec for the 'H' model 200 kawi. Easiest way to know what YOU have is to check what YOU have.
BTW, a stock needle chart is on CDave's site:
http://justkdx.dirtrider.net
under <tech tips> <understanding jet needles>
(Man....I can't believe how many times I've linked that site)
Do yourself a favor. Replace the bowl screws with some allen heads. Get a ball end wrench to wrench 'em. Use an anti-seize compound on the threads when you put them in.
dazza: picky picky picky ;)
sledman
160
And what effect (harder hit, smoother transition) would the CEL needle have, compared to the stock needle, and what position would a guy want to start in compared to #2 on the stock needle? Who makes the "CEL" needle? Just wondering if the local Kawi shop might stock one.
canyncarvr
4,005
That's a keihin number. Sudco, carbparts (for examples) sell keihin parts. Sudco..800-998-3529 or carbparts.com
The 'R1174K' (ex) needle is a kawi proprietary needle FOR the keihin carb.
'C' is the taper of the needle...1º34". The oem kawi is a 'B' series needle, or 1º15" (that's 1 1/2º and 1 1/4º respectively).
Start the CEL @ #3.
Note the kawi 'K' needle has a 38.60mm L1, the CEK is 38.15mm. The distance between the clips is .90mm. At the same clip postions then, the CEL is 1/2 a clip shorter (richer) than the 'K'.
My experience with the faster taper 'C' compared to a 'B' is that it hits harder.
Maybe one down on the pilot with the CEL over the R1174K due to diameter (2.705 vs. 2.735mm) differences.
OLD-N-SLOW
168
Dang CC. you got a lot of info in a small space! Could it be your getting less windy? Lets hope not, as I for one like reading your broken,
staggerd and sometimes funny replies.
Boy san and sledman please reread cc's last reply!!! Thats $100.00 worth of info. Please make check payable to old-n-slow c/o DRN.
Steve
canyncarvr
4,005
O&S: I'm reacting to a 'lesson' I got recently regarding being unspecific, verbose and wide of the point. :(
Don't know about the less windy part. Flatulence (complete w/oily discharge, an increased tendency toward and inability to control it) wasn't part of the lesson.
Broken? Staggered? Those are good things?? ;)
Fred T
5,272
Yep, you guys are right. I missread that and thought I read a 220. My mistake. CC made the call and reasoning on the CEL. The 1/2 clip richer thing in the midrange keeps the bike running stronger. Jet needles are like $5.00 a piece so getting a few to try is a good idea.
canyncarvr
4,005
I haven't verified this, but I believe JD said to try to match needle profiles at 1/4 throttle? Anyway...a CEL/1174K comparison (thanks to JD's spreadsheet!) shows that to be so.
A key point to keep in mind with needles... The faster the slope (higherº number) the LATER the angle starts on the needle given the same L1. THAT'S because L1 is really NOT the length of the straight section, but the length TO a 2.515mm diameter. That's referred to as the 'magic number'.
So, if you angle steeper, you start later. Make sense?
That's one of the reasons that although the CEL is a shorter needle it's clipped lower, too.
One more thing (I'm rolling now O&S!). If you end up looking for a throttle valve (slide), give ron @ RB Designs (of RB carb mod fame) a call. I ordered a #6 (#5 stock) twice, got the wrong part twice. The whole process took weeks!
Ron had the correct one to me in a couple of days.
canyncarvr
4,005
Not a direct relationship, no.
Just something to keep in mind when you think you're changing to a 'leaner' needle (say one that has a larger straight diameter and tapers slower) only to find that your bottom end is fat and you foul plugs on long downhills (idling for awhile).
Which is what a lot of the problem was with the 'A' (1º) series needles originally fit to the RB carb.
The largest diameter needle I've tried is the CEK (with a #7TV). Hit very hard and pulled in upper 3rd gear something fierce!! In fact, TOO hard for a long day's ride. At the end of a 70 mile ride, I was pounded to a pulp.
On the coast (sand) it was fine with my kg-30. In the woods? Aarrgh! :(
