HillTopper
- Aug 22, 2001
- 13
- 0
Strange substance in XR's oil(please help), long story
a while back, i went to adjust my valves on my 98XR400, when i noticed on the inside of the side cover cap(the big one in the middle) that is used to turn the crank to adjust the timing marks, that there was some strange brown substance on the back of the cap itself and around the bolt inside. this is the tough part: its very thin, brown and it when i touch it, its almost like a wax. its not grainy in any way, but it almost looks like the color of muddy water. it wasnt all laying at the bottom, it was stuck to everything.
i've changed the oil in it and put new stuff in, ran it, changed it again. did that about 2 or 3 times and checked it again. most of it was gone, but i could still see some of it.
a few weeks prior to all of this, i had fallen in a huge mud puddle and most of the bike went under. when i got out of the mud puddle, the bike started on like the 2nd kick after giving it a good number of primer kicks. to be safe thought after that ride, i drained the oil, and there werent any signs of water contamination at all and none of this crap was coming out of it. so i figured all was right.
here are a few of my ideas on what it could be:
1.wax from oil(i use bel-ray 10-40 4 stroke oil) or some sort of condesation from hosing it off right after riding.
2. clutch wear. just today though, i took the plates out and inspected all around the area and there was no signs at all of any foreign objects. even behind the basket, looking at the internals with a light, it all looked brand new. there was nothing on the clutch side of the bike and the plates looked excellent.
3. a mechanic told me that on the stator wiring, there could be a varnish coating over them which could have come off and thats what this could be since it does seem to be only on the flywheel side.
4. my worst fear. dirty water has got into the engine.
i'm sorry for the length of this post, but i'm hoping someone out there has experienced something like this and can ease my troubled mind. as of now, the bike runs perfect but does give a very little of black smoke when first started(no, it doesnt fill the driveway up, its just visible when revving it), when warm though its gone. thanks. i'm done writing now.
