I went too take off my radiator shroud and the bolt that goes into the gas tank spins freely.. DOes anybody have any reccomendations on how too fix this??
Thanks in advance,
RIck
Can you mix up some 2 part epoxy and get it in there without getting it on the threads also? Maybe use a toothpick or a cut down popsickle stick to push it around the outside? Let it set real good and then try to remove?
Ok, I know this one...
Check your nutzert, it's hexagonal (six sided), Yamaha uses four sided inserts because it's less likely to spin loose. The angle between each side is 90º instead of 60º.
I took my tank to a plastic welder, and he filed down two of the six sides, thereby creating a rectangular insert which is much less likely to spin.
It cost me two bucks, and it hasn't spun since.
I used a needle nosed vise grip and held the nut and broke the bolt loose. Had to do some digging with my dremel tool to give me the space to get a good bite with. As long as you don't go to deep you will be ok. The nut is a lot deeper than you need to go. Just stay close to the nut. After i got the bolt loose I created a rectange for the rectanged nut on the YZ and CAREFULLY filled in the space between the nut and the tank with JB weld. I always use antiseize on these bolts now.
