Succubus
99
I'm trying to change the forks seals on a 1979 Suzuki TS250. So I crack the retaining bolts that go through the bottom of the outer leg into the plunger. I'm unscrewing them, thinking what a talented tinkerer I am. Boy, this is going to be easy. Life punishes the smug. So I turn and I turn on the socket head bolt that holds the plunger to the bottom of the leg and I notice that even though it feels real loose it just keeps turning. And turning. The screw came partly out and now the cylinder is turning with the bolt and not getting any looser. So I figure I'll get back to this one and I go to the other leg. Same thing. About this time, a couple hours into a 30-minute project, I start thinking about how to keep the cylinder from turning so I can get the screw out. I briefly consider - in all seriousness - flattening the lower leg with my sledgehammer. That will keep that sucker still. I also consider filling the leg with cement and letting it set. It occurs to me, though, that either of these methods may compromise the forks ability to absorb shock once remounted. Anybody faced this before? Any ideas how to keep the cylinder from turning so I can get these stupid bolts out? Thanks and Merry Christmas. Pat
Papakeith
COTT Champ Emeritus
6,695
51
RI
Have you already removed the spring from the fork leg? If so, put it back in and replace the cap. This will put pressure on the inner fork tube, and allow you to back the bolt out the rest of the way.
dirt bike dave
5,348
Not familiar with your specific TS forks, but if you had a shop manual it would probably show a specialty tool that slides inside the fork tube and keeps the damper rod assembly from turning. These tools usually look like a long tube with a couple of notches cut out of the bottom. The notches fit over little pegs at the base of the damper rod. You hold the tube/tool, fixing the damper rod in place, while you unscrew the hex head bolt.
One of my friends made a tool using a metal vacuum cleaner hose extension. He shined a light into the fork to see the orientation of the pegs (there were two, 180 degees apart), put some notches into the vacuum cleaner extension to accomodate the pegs. Worked great. I think a thin wall metal tube or pipe of the right size could be made to work.
Succubus
99
Thanks, Dave. I'll have to give that a try. The bolt is loose enough for oil to drip out, but for some reason it stopped turning about halfway out. I've tried pulling on the inner tueb to create drag. Nothing. I tried pushing on the inner tube to try to keep the cylinder still. No luck. I've already tried my impact wrench. It just spins the bolt. I also put the spring back in. I felt some resistance after that, but not enough to get the bolt to turn out. I even put in a spring I had from another of my bikes that was longer and it provided more resistance, but that sucker still wouldn't come free. I tried jamming a broomstick down the tube, but it couldn't get a grip on anything. I tried removing the fork oil drain screw at the bottom of the leg and jamming a small screwdriver into the hole to try to hold the plunger still, but it found nothing to grip. I've got some old tubing, including and old vacuum. Now that I know what kind of tool to try to fabricate I'll give it a try. Here's hoping I get lucky.
John Harris
552
Use of an air impact wrench is often the fix--amazing how much better it is on something like this than manual tools. Dave above has the fail safe approach! Now you have something else to do over the holidays. Cheers John
VintageDirt
Baked Spud
3,043
9
Like PK says, put the springs back in and if that doesn't do it compress the forks with a tie down, that works every time.
Succubus
99
A ratching tiedown and air impact wrench. Bingo. Now to pry out some 26-year-old seals. Once again, the friendly folks on this board gave me the answer. Thanks guys.
Merry Christmas and I hope all your teams win their bowl games.
FRESH VIDEO
