:bang:
After 1500 miles of use I noticed the rear Wheel hub bearings are in need of replacement, being the back wheel moves slightly from side to side. I removed the wheel, the retaining clip on the brake side and started to remove the bearings. The bearing on the sprocket side came right out after tapping a straight rod all the way around the inside with a hammer. Even after removing the retaining clip,applying Liquid wrench and tapping around the bearing as described above, the bearing won't budge on the brake side. In tapping harder the bearing self destructed leaving just the stuck outer ring. Now what, should I try heating the ring with a torch? Please help.
