Race Fuel Transformation
I purchased some Sunoco GT Plus 104 in a sealed five gallon steel container to try in the YZ426. I rode yesterday and after about 10 minutes the motor starts popping real bad going into the turns and also stalling. I figuire maybe the jetting is off so I pull the pilot jet and it's plugged solid and the carb has an ultra fine brown crud in the main jet cap. I pulled the bowl and find more crud. I cleaned the jets and bowl and ran it again hoping the previous fuel ( not the Sunoco ) was the problem and the GT Plus being new and put into a drained tank and carb would work ok. After cleaning the carb I ride it about 10 more minutes and the same thing, plugged pilot jet, but it runs good until the jet plugs up.
I get it home and flush the tank, petcock, cap vent, etc and disassemble and clean the carb. I filtered all the fuel from the tank thru layers of fabric and find a brown stain in all the filters. I put some fuel that had been drained into a white plastic cup, after several hours there is a brown sediment on the bottom. Just for grins I took some fuel that had only come from the Sunoco container and put it into a sister cup. After a while the new fuel has this brown crud. The fuel was new to me about a week ago and came in an unopened steel container and has been stored in the steel container until put into the tank that morning. Anyone have any thoughts as to why the fuel is changing? Also the Sunoco wasn't mixed with other fuel or any additives.
PK
PK
