Blackcat said:I read about this somewhere where a guy had to take his bike to tire shop and the guy had to hit it with the heavy duty airgun. Just a thought. By the way what does PB mean.
Blackcat said:So you cut the head and the nut off the bolt, right. How about something like a jackhammer with a long pin in the tip.
2strks4evr said:DON'T YOU DARE PART THAT BIKE OUT!if the bolt will move at all in either direction,move it as far as u can then cut the end in which it was moving then move the bolt in the opposite direction until it stops and cut the other end,then move the bolt in the direction you moved it the first time.presto it should come out?!good luck
His problem is not getting the nut off, it's getting the seized bolt out. Not sure what else to tell you that hasn't been said. In the end a good air hammer, or better yet a hydraulic press, sure as heck should get it out.mox69 said:Here's a tip I learned from the 4x4 off road people who used to work with 20 year old rusted U-bolts.
Start by heating up the bolt in question with a torch. Don't get it red hot, but get the nut nice and warm.
Now MOVE THE FLAME AWAY and spray the bolt with WD-40.
Wait a few minutes, reheat and respray.
What happens is when you head the nut up the metal expands. When you spray it with WD40 it cools down and contracts. As it contracts it "sucks" the WD 40 into the threads.
Try it, it works great for me.
