Atticus345
5
I spent a while searching but didn't find quite what I was looking for. I've got an 85 Honda CR250 which apparently is having float/float valve issues. It leaks fuel out of the overflow and when I took the bowl off, the float pivot pin was halfway out and is a very sloppy fit. It appears to be the stock Keihin PJ, and the size I am uncertain of at this point, but would I possibly benefit by switching this carb to a PWK of the same size? If so would I be better off picking one of these up rather than spending the time and money to fix this one?
On another note about this carb, I noticed that the slide had some scuffs on it where it appears some of the finish has worn off, which makes me nervous that it could possibly stick. Is this a legitimate concern?
