Well, in my plight to be a cheap and impatient mechanic I broke my cluthwheel while attempting to remove my cluth assembly.
I made up an aluminum jig that bolted to 2 posts of the cluthwheel and rested against the waterpump. This stopped the rotation of the basket so I could unbolt the clutch from the crank. Apparently, this was not the best route I could have taken since the moment I applied sufficient force to remove the nut, SNAP! Off came one of the post from the cluthwheel.
My question for you guys is, when I replace the cluth with an aftermarket cluth, such as Hinson, will it come with the cluthwheel that I broke? This part is not pictured in any catalogs, but since all clutches are different for differnet bikes, I am not sure if that if it comes with my bike or not.
The part that I broke can be seen here at the Kawi web site. It is part #13086-1069.
http://www.buykawasaki.com/Default.asp?strContentURL=site/VIVehicleInformation/VIChooseVehicle.asp?intCatalogID=2&intParts=1
Do I need to buy this from Kawi, or does it come with an aftermarket clutch assembly. Thanks in advance gents.
Brad
Brad
