The Honda Pilot
- Feb 25, 2001
- 394
- 1
On my 2001 cr 125 I think the routing could have a problem when I turn the handle bar to the left or right the throttle starts to turn on me ..NOT FUN on the track when in a corner. Anywho this is how I have it routed its comming from the grip over the center bolt going through the front # plate. between the left fork tube and the frame. Then runs down along the right side of the left radiator between the frame and the right side. Then it comes out right near the spark plug runs to the left of the plug and rubs rite against the engine triangle mount. Then goes striaght into the carb. Im going to tear down the carb and clean it again and take the carb slide and its part of the carb that is touching it and buff it a bit to see if it will slide better.:eek:
