Cr85Expert52
- May 25, 2003
- 22
- 0
heres what you do and I did it the first day I got my bike. You take a piece of like 1X1 wood and cut it to fit in between the front tire and underneath the fender. leave about a 1/2 inch gap so the front will go down about a 1/2 inch and then the wood is blocking it from going any further. Sand the edges down on the corners of the wood. Then get a washcloth and cut it to go on top of one side which would be the fender side so the bottom of the fender doesn't scratch. Put the washcloth on one side of the wood and staple or duck tape it to hold. Then when you put the bike in your truck place the wood in between the front wheel and underneath the front fender and make sure it's on an angle parallel to your shocks. Tie it down and there you go not to much pressure on your seals and springs.
