Timing and tips on a Stroked Engine.
I have a 2001 RM 125 That I had the Crank Stroked on. Does Anyone know if This Will have an effect on the Igniton Timing of the Bike??(Say I left it in the Stock Setting) Also, does anyone know how to figure Blowdown duration from Degrees of opening from exhaust to the ports?? Also, does anyone have any advice on Tuning This Engine?? I'm trying to learn as I go and do everthing myself. The only thing I haven't done is balance the crank,(didn't have acess to a balancing machine. Any help will be appreciated. I'll post all results I get.
PIPE FMF SST
SILENCER FMF SHORTY
V-Force REEDS
Cases Cleared for Crank(increase in Crankcase volume)
Porting- Stock
Stroke 64.5
Bore 54.0
Deck Height .03 above top of cylinder.
Squish Cleareance 1.1mm
Squish Angle 10 Degrees
Exhaust opens at 76 degrees ATDC
Ports at 100 degrees ATDC
ROD Length 100MM
Base of cylinder spaced up .08 overall.
PIPE FMF SST
SILENCER FMF SHORTY
V-Force REEDS
Porting- Stock
Stroke 64.5
Bore 54.0
ROD Length 100MM
