Timing and tips on a Stoked Engine.
crawl9
Trial Subscriber
32
Timing and tips on a Stroked Engine.
I have a 2001 RM 125 That I had the Crank Stroked on. Does Anyone know if This Will have an effect on the Igniton Timing of the Bike??(Say I left it in the Stock Setting) Also, does anyone know how to figure Blowdown duration from Degrees of opening from exhaust to the ports?? Also, does anyone have any advice on Tuning This Engine?? I'm trying to learn as I go and do everthing myself. The only thing I haven't done is balance the crank,(didn't have acess to a balancing machine. Any help will be appreciated. I'll post all results I get.
PIPE FMF SST
SILENCER FMF SHORTY
V-Force REEDS
Cases Cleared for Crank(increase in Crankcase volume)
Porting- Stock
Stroke 64.5
Bore 54.0
Deck Height .03 above top of cylinder.
Squish Cleareance 1.1mm
Squish Angle 10 Degrees
Exhaust opens at 76 degrees ATDC
Ports at 100 degrees ATDC
ROD Length 100MM
Base of cylinder spaced up .08 overall.
bclapham
4,340
just out of interest crawl, how the hell do you manage to get the big end of the rod to fit inside the cases? i think the usual for these motors is a 4mm longer stroke (pin offet 2mm) but i cant see where the room is for the 5mm offset with your 10mm stroker?
sounds fun all the same, hows itt run???, good luck.:)
ps if it doesnt work out wiseco complete cransk are only $180
mxneagle
320
Rich or eric posted a great article on timing a while back. I did a quick search but didn't find it. Please try digging around in this or the advanced tech forum. As for the timing, I wonder if it's the actual position of the piston that is important (ie so many mm's before TDC) which you could calculate to be the same as stock. Or could it be the amount of time it takes for the piston to travel from the ignition point to TDC. My guess is that it's probably much more involved than either of those but trial and error (otherwise known as empirical data to scientists) methods may prove to be the most successful.
crawl9
Trial Subscriber
32
I just ran the bike yeasterday for the first time with the stock settings(Jetting, timing,etc.). To get it to idle, I had to run the Idle screw almost all the way in, much farther in the before the stroked crank. It run perty good on the stand,
seems to be loading up a little. Proably the jetting. When I rode it, it was real
sluggish down low. haven't reved high yet. just breaking it in. Does Changeing you Timing Effect your Jetting in anyway? To get the Crank to Fit, I had to cleareance the cases and take some off the bottom of the rod. I also did a search before posting this thread about Timing but couldn't find anything either.
crawl9
Trial Subscriber
32
I ran the Bike again today. I did the jetting and had to lean everthing up.
Also I tried to retard the timing and the bike ran horrible. I advanced it and it started to run better. Runs good down low but Falls Very,very flat on the middle and on up. I was wodering what the best way to tell if you bikes running too hot or not? I have a temp sensor I can check the outside temp of parts, can you get a reading off outside of pipe to give you a general idea??
marcusgunby
6,450
With only a longer stroke im guessing it will always be a tree puller, you need to open up/raise the ports as much as possible to offset this.
RKT
12
Crawl.
Not sure how the bike is currently runnig, BUT with a 76 degree power stroke and 24 degrees of blowdown.. I am pretty sure that this bike will have major issues with power delivery.
Are you sure those numbers are right?
Kelsey
jaguar
1,516
82
South America
Yeah, I'd say that's a bit off.
My KDX200 has exhaust port opening at 96 degrees after TDC (83 when power valve opens), and the transfer intake ports at 120 degrees.
The following is from Eric Gorrs site and may be useful:
Tuning for Specific Powerbands
I've designed the chart shown below, to give you some general guidelines on different powerbands and the changes required to the individual engine components. For specific recommendations on your model bike, refer to the chapters on tuning tips.
Component: Cylinder Head
Low To Midrange: 9.5:1 compression ratio, squish band 60% of bore area
Midrange and High-Rpm: 8:1 compression ratio, 40% squish
Component: Cylinder Ports
Low To Midrange: Exhaust port 90 ATDC, transfer ports 118 ATDC
Midrange and High-Rpm: Exhaust port 84 ATDC, transfer ports 116 ATDC
Component: Reeds
Low To Midrange: Dual-stage or .4mm fiberglass petals.
Compromise: Thick carbon fiber petals
Midrange and High-Rpm: Large area 30-degree valve
Component: Carburetor
Low To Midrange: Smaller diameter or sleeved down carb (26mm for 80cc, 34mm for 125cc, 36mm 250cc)
Midrange and High-Rpm: Larger carb (28mm for 80cc, 38mm for 125cc, 39.5mm 250cc)
Component: Pipe
Low To Midrange: Fatty or Torque
Midrange and High-Rpm: Desert or Rpm
Component: Silencer or Spark arrestor
Low To Midrange: Short, small diameter
Midrange and High-Rpm: Long, large diameter
Component: Ignition Timing Advance timing
Low To Midrange: Stock timing
Midrange and High-Rpm: Retard timing
Component: Flywheel
Low To Midrange: Add weight
Compromise: Stock flywheel
Midrange and High-Rpm: PVL internal flywheel
Component: Fuel
Low To Midrange: Super unleaded 93 octane
Midrange and High-Rpm: Racing fuel 105 octane
