Hi Guys
When the manual states that the timing is 21 degrees before
TDC at 6000 rpm, does that mean it is at full advance or will the timing be advanced even further with the revs climbing or is the timing already on a retarding curve when it hits 6000 rpm?
If the timing is already retarded at 6000 rpm, then is there anyone out there that knows what the full advance is and
at what rpm this happens?
From reading some posts, it seems that full advance happens around 3000rpm at about 25 degrees and then retards to 21degrees at 6000rpm and then progressively retard as the revs climb.
Is it safe to say that 8 degrees before TDC is the timing for
idling speed (1000-1200rpm)?
The info I need is for a 98 KDX 200 (normal not international)
I would appreciate all info
Cheers
Stephan
Cheers
Stephan
