Tired of squishy, pumped up front brake...
va_yzrider
353
I'm sick and tired of my squishy, soft front brake. Which aftermarket manufacturer makes the best braided front brake line for use on a 2001 YZ 125? Further, I would like to do a more "Honda-esque" brake line routing. If I get a brake line for the YZ, it will be too long for the straight routing, right? Or, does having a braided brake line eliminate the need to re-route the line all together?
Thanks. Hopefully no more of this :eek: as I'm slamming into a berm.
elf
695
I dont know which one is the best but I use the fastline on my yzs. Yes its shorter than the stocker and works good in the honda position. Just make sure the one you buy says it works for honda style routing.
va_yzrider
353
Thanks elf. I'll look into the fastline. I just wasn't sure about the length and routing, but it sounds like it worked well for you.
