cr2504life
- May 17, 2004
- 141
- 0
It is just about time for a top end rebuild on my cr. The previous owner had a new sleeve put in and i know that i will have to bore it out a little(slight scratches in the bore). I was wondering when i do this will i need to modify the exhaust valve to avoid contact with the piston? If so how do i go about this? I will also be replacing the main bearings. Do i need any special tools to do this. Ive heard that sometimes you need a press and a "case puller"??? Is this true? Also after the rebuild what compression numbers should i look for? Thanks
