The anodized applied are pricy, i'd say RG3's new clamp is too. I'm assuming you are talking of bar mount rise. Well, most clamp manufacturers offer different size bar mount heighth's get some of those, then if that's not high enough get some ape hanger bars. Then.... if that doesn't work you're too tall for an 80 and you need to go buy a new CR 125!
I went with Applied's Works top clamp, with the 15mm taller, offset bar clamps. The top clamp moves the bar mounts further forward than stock, plus the offset, taller bar mounts moves the bar position even further forward and higher up. Applied's pricing is great for their 'works' clamps and the fit and finish is second to none.
