Originally posted by A KDX BUZZ
I would try using a 6-point wrench rather than a 12-point,(as pictured) to reduce slippage/stripping.
It's only 18 lbs.of torque for goodness sake.
The Motion Pro adapter is the right tool for the job. Remember to torque in stages in a crisscross pattern. (loosen the bolts in the same way). I would also think twice about slipping any pipes over wrenches before touching head or cylinder bolts. Cyl. should easily come off with a tee-handle and 12mm socket. Minimal effort is needed with the PM adapter. :silly:
