Green Hornet
- Apr 2, 2005
- 837
- 0
I have some info regarding the calibration of the Trail Tech Computer. After using the calculating numbers provided in the instructions, the Digital Speed did not seem to coincide with the approximate visual speed. I used the stock odometer to calibrate the computer. Set the Wheel Size to 2205mm and then drive a known distance (I used 1 mile) Multiply these two numbers 2205 * 1.00 then divide by the milage displayed on the Trail Tech (My case was 2.05 miles) 2205*1.00/2.05=1021mm (Approximate) I then used GPS to verify the speed & the stock Odometer to verify the milage & its seems to be close to dead on. I emailed Trailtech about this huge discrepancy and am awaiting an answer. Just some info for you guys to check your computer, because I doubt I'm the first.Trail Tech recommended the W/S @ 2110mm(NOT). It is a nice setup though :cool: :ride:
