KrazyKX
4
Ok, i have a 1990 KX 80 with a 100cc jug on it, the tranny is still the same one from the 80. finally got the thing back together and now the gear shift lever just kinda flops around. If you upshift the thing stays up so you can't upshift anymore unless you knock it down with your foot. And down shifting is the same thing. won't let you downshift anymore unless the shift lever is raised slightly with the foot. i was looking at the schematic on WWW.BikeBandit.com and it looks as though the double sided spring in there might have failed. If anyone knows an easy way to fix it (hopefully with out cracking the cases) then i would appreciate it a great deal.... thx in advance
83MX80
347
personally the way i see things. is that the only way your going to know what exactly happen or whats the problem, is splitting the cases.
