dante
555
I know I need to replace my water pump seals, and crank seals... Trouble is the shop were I go does'nt sell water pump kits or crank seal kits just parts by part numbers... I was over at BikeBandit.com and found this
http://houseofmotorcycles.bikebandi...d~305480~model_dept_name~KX125(KX125L2)US.asp
hopefully the link will work...
it shows a diagram of the waterpump, and both cases and all the parts inbetween... Basically my problem: nothing is called "waterpump seal" or "crankseal" by name I just want to make sure I get the right stuff
I was able to find the oil seals, and the impeller... and pump cover gasket... What other parts will I need... Here's a list I have made so far...
Impeller 59256
oil seal 92049
seal oil 92049a
seal oil 92049b
seal oil 92049c
ring-o 92055a
collar 92027
collar 92027a
pump gasket 11009a
ball bearing 92045
ball bearing 92045
thanks for any help, I know I can do it, but not with out all the parts...
