I decided to finally try and check to see if I had the correct pilot installed. The bike is 05 KDX200 with aftermarket pipe and exhaust with the airbox lid removed. I pulled the carb to make sure of the pilot (42) and then warmed the motor. I followed the typical jetting instructions...
"Turn the airscrew slowly in, and then out, until you find the point where the idle is fastest. Stop there. Now is the time to determine if you have the correct pilot installed in your carb. The airscrew position determines this for you, making it very simple. If your airscrew is less than 1 turn from closed, you need a larger pilot jet. If it is more than 2.5 turns from closed, you need a smaller pilot jet."
The way I understand this is to turn the airscrew in and out until you find the fastest idle (highest RPM). That is where my problems begin. The idle continues to increase the farther out I turn the airscrew. There is no up and down to the RPM's, it is just all up as you turn the airscrew out from fully seated. Am I doing this wrong or does that just mean my pilot is to large to see a midpoint where the RPM's fluctuate and that I need a smaller pilot? I am just not sure if I want to go much smaller on the pilot.
