greets from austria & sorry for my bad english
hope i´m in the right column with my stuff...
my bike: KTM 380 ´99 2 Stroke (Supermotard-conversion - you know, the small wheels...)
finally i did it - competing in supermotard-races...the result was: driving is fine, but the bike-engine is TO WEAK compared to others on the track.
anyone ever tuned a 380 engine ? i´m thankfull for any information.
my plan: a few aftermarket-products combined with a porting job on the barrel, some mods at the cylinder-head for higher compression-ratio, making the piston "fitting" to the porting work, setting up carb and the TVC very correct etc etc...
in my thoughts were some after-market products like:
*an FMF-Fatty
*Delta II Reeds
*a forged piston (wiseco?)
my questions:
is it possible to insert a forged piston into a barrel which once run with a cast-iron piston ? there should be a rebore before, right ?
porting work: ANY ideas ? anyone ever done something on that barrel ? anyone here who can give me any useful porting-times, any angles or any other useful data, so that I don´t have to start from ZERO.
needed is more top-end, but more torque would also be VERY FINE ...
the work is going to be done from a very good italian 2stroke-tuner (up to now he doesn´t know from his "luck" that he will make the job *smile*).
problem is that this guy never worked on that kind of bike, so I want to bring him as much pre-information as i can get for him
I hope someone can help me.
hope to hear from you !
thx !!
Ivan
*an FMF-Fatty
*Delta II Reeds
my questions:
thx !!
Ivan
