hey I can get a crf250x pretty cheap, however it was drowned in a creek really badly. The guy says he got all the water out of it, and it runs (though the top end is in bad shape and from the massive amount of backfiring i'm assuming the valves are waaaay out), but the starter, wiring etc. is all friend. Since I'd use the bike for mx, other than the wiring, the battery, electric start, 37mm carb, wider ratio gearbox, and 18inch wheel, what is different? If I get the whole engine rebuilt can I just get them to put in the same valves as the 250r, then rip all that wiring out, stick a number plate on it and call it a 250r with an custom 18" wheel, 37mil carb (to reduce bog of course :nener: ), extra engine ballast (the starter :) ) and a wider ratio gearbox... or am I out to lunch? haha thanks
PS - the bike is a 2006 - it has an fmf single muffler and powerbomb header so I won't have to worry about that...
