Mm mumble, put it this way when I bought mine it didn’t feel too bad there was about half an inch movement at the rear wheel. Only one bearing was kuzed.
Take it apart, it needs to be regreased every so often or it WILL die. You may find a couple munched but save the rest.
Do a search on rear suspension bearings when you find out the guts.
