URGENT Help pic how to measure float level!!!
helio
258
I would like to ask if somebody can please send me a digital image about how to measure the float level...
Thanks.
BTW I have a PJ 36mm and I am trying to measure the 16mm CORRECTLY!!!
Durt Cycler
Trial Subscriber
1,173
This is what you should do when measuring the float level.
1. Tilt the carbs so that the floats just flop over towards and into the carb body.
2. Tilt just enough to touch and close the float the float valve, but...
3. Do NOT compress the float valve spring when measuring.
4. With the metal adjustment tang on the float just touching, but not compressing the float valve spring, place the Setting Gauge over the highest part of the float. If there is a gasket or o-ring stuck to the carb body, remove it while measuring.
http://justkdx.dirtrider.net/images/float2.gif - Click here to see how it measure the height.
