:I'm doing a top end job on my KX125 and am replacing the original piston with a Vertex. I had a couple of questions about them if anyone here has any experience with them. I buffed the whole lower end of the piston w/ scotch brite to make sure there aren't any jagged edges touching the cylinder. When I installed it on the rod I found out that the circlips that came with it fit REALLY tight, they were rather difficult to seat. I've never seen circlips that tight on any OEM Japanese piston (Vertex is Italian). Also I've been told that Vertex makes different size pistons for the same cylinder bore, to account for wear I would think. The one I have says it is 53.97mm, My KX cylinder is 54mm. Anyone with any experience running these pistons, I would appreciate your comments! :clue:
