elf
695
You can get a different top tripple clamp like RG3 with rubber mounts to help cut vibration. Also Fasst company makes anti vibration bar inserts. As for the pegs Try some gel insoles in your boots.
a454elk
Mexicutioner
7,529
18
Try softer grips too. Don't hold on as tight, just enough to keep control, loosen up the grip and bend your elbows a bit. You may be riding too rigid.
