This is my friends bike:
http://mlbobbitt.home.attbi.com/1983_200.jpg
1983 bike with a stock pipe and for what we know a stock top end/carb on the bike. Forks were a direct swap from a 86 kdx with a mid 80s CR master cylinder. He really needs to install the black boots! Went from a 38mm to a 43mm front fork. Installed Xr400 front springs. Out back we installed a lift also! Used some 1/4" plate steel and make an extension on the dog bone side. Drilled new holes and that ended up lifting the bike about 2-4". Then dropped the forks level with the top clamps. Works out really well. He is 6' + and me at 5'8" I can barely touch the ground. We are going to cut and weld the pegs down about 1-2". Cr high bars, mid something KX seat cover and 87 KDX sparky on that. Took one piece of metal to make an extension bracket for the back bolt.
The bike is not pampered, but runs like a top! The maxxis CT6001 tires hook up on anything out here on the oregon trails!
Enjoy
Enjoy
