Jon K.
- Mar 26, 2001
- 1,354
- 4
dante said:Why don't they just fine him like a 50k or something like that, why take points from the leader... :bang:
A monetary fine would not hurt a big team.
Taking points away certainly does.
Jon K. said:When you get busted for speeding, do you tell the cop that the limit is too low? More to the point, do you get a break when you tell the cop that the limit is too low?
Ryone said:It took three instances for VP to finally step up and say something. I think they were tired of others making them the scapegoat. VP probably provided fuel to the other 7 bikes that passed inspection. They don't have a problem meeting the specs in the rulebook, but they have no control as to what happens to their fuel once it leaves their stockpile.
I'm not sold on it either. I'm just stating that parts/billion is sooooo trace (especially in a 2 gallon gas tank) that it's possible.dklink2000 said:I'm not sold on the "dirt in gas" theory.
I totally agree. Passing the buck may not be the best approach. If they provided hard facts instead of pointing a finger, their open letter would read a lot better.Chili said:If that's the case why would VP not step to the plate with data showing their quality control process and relevant testing data to show they can meet spec 100% of the time?
I think that since the amounts were all close, it shows that something similar may have happened to all samples. Possibly, as suggested earlier, the samples were collected irresponsibly. Also possible is that the fuel they all used was exposed to a similar contaminant in a similar fashion. It's tough to speculate, but exceeding .005 g/ML by .013 g/ML is still rediculous as far as the rule is concerned, and in NO WAY WHATSOEVER should be consdered as an attempt to cheat by any rider.Chili said:As for them having no control after it leaves their stockpile, do you really think that Yamaha, Kawasaki and now Suzuki all managed to contaminate their fuel to almost the exact same amount?
dante said:...If he does'nt win the chapionship it sure takes away some of the prestage of winning it this year for someone else...
That doesn't even help if the sample gets contaminated.zcookie49 said:I can see the future if the rule stays the same "team fuel will be secured in armored trucks, where they will have to completely clean the bike before entering the super sterilized fueling station with people in silver radioactive suits to dispense fuel" OR maybe there is a "dirt fairy" around, sprinkling dirt particles into gas to taint it. LOL.. haha
CJG said:Since I haven't seen a crazy conspiracy theory here in a while, I guess I'll have to start a new one.
Easy. It was just a ruse concocted by Whitelock to maintain the appearance of fairness. Knowing all the while that they were going to overturn the penalty, which they promptly did. :nener:Jon K. said:How does Whitelock's penalty toward KW (for punting DV into the cheap seats) fit in with your theory? :)
Well, that blows a perfectly good conspiracy theory out of the water. You're right. A plan that elaborate would require forethought, planning, and intelligence. All areas in which the AMA is sorely lacking. :|HiG4s said:I pick . . .
F. Not true at all because is would indicate someone at the AMA actually has a brain.
