have been waiting for a manual for a 97 200, but it appears to be taking the boat a lot longer than the 4 months on back order. Have done searches but none accuarately describe my question. having pulled the fork legs off & their respective boots. The item between the inner & outer fork legs are in deed the dust wipers for the seal (sorry used to usd forks), that can be prised up to clean out. i think this has never been done. Also changing fork oil undo top nut and simply drain out, have done this on other bikes. just checking that there are no little catches. If this is done with the spring still connected what is the best way to measure oil level, or is this done on quantity and not level.
Sorry if this is a repeat but i have searched and found items that didnt clarify things as much as i wanted. Sorry for any inconvenience.
