i have a 1990 kdx 125 and was filling up the radiator and have found that all the water has leaked into the gear box and some.
does anyone know why this could be??
all the water? man allot of us seem to be having these problems latley me included... all kawi's too :think: but mine was leaking just a litle bit, not all the water... Here's what I replaced... Under the right side big clutch cover there is an O-ring, that seals the water from the case, you can't miss it... I replaced that, allong with the water pump gasket, the oil seal in there, and water seal that is on top of that... Plus I replaced the impeller shaft and bearing... good luck :cool:
