BGMRC
- Jun 6, 2008
- 40
- 0
hello all,
2 questions...
1. if anyone can assist with water leaking out of the bottom screw from water pump cover. I just replaced impeller and new gasket installed and the water pump cover has a spot cut out for some reason I can not understand and water flows thru the cut out area and comes right thru the screw?? if I pull the screw water flows directly right out the whole...
2. the impeller I just purchased, I can not get it to mount snug onto the shaft...its just loose, Is that normal??
Thanx in advance for any help....
2 questions...
