BullDog KX125
- Mar 9, 2001
- 76
- 0
I have a small amount of coolant leaking into the trans, not much seldom loose much coolant, maybe an ounce every now and then, but the oil gets milky. Can I replace the water pump seal by only removing the water pump and impeller, or do I have to remove the case cover?
