For the past month I have been in the process of rebuilding my dirtbike, a 91' KX250. I just split the cases and have to re-tap the threads for the drain plug, ut last night I came up with an idea. Instead of re-tapping for just a bigger standard or metirc thread, couldn't I buy one of those FRAM trick looking oil change systems, the ones that you screw in to your drain hole permanently and use a special hose attachment to drain your oil, and use that. I figured this would be a great idea because I wouldn't have to take the drain bolt out every time and risk screwing up the threads again. I already have one in use on my Ford Ranger, and it works slick. However, do you think it would have any weaknesses used in a dirt bike. I have a skid plate to protect it since it sticks out a little more than a bolt would, but please, share your thoughts on this.
Here's the link http://www.autobarn.net/frasdseries.html[url/]
