Hi
I have a yamaha tt350, i have had this problem which is getting worse, if i hold the throttle constant in the mid range revs there is a really harsh sounding vibration, and its missing a little, but its not there at idle and it goes away when you twist on the throttle .
The plug always shows a really rich colour. I have tried every possible jetting combo, and made it rediculously lean and it still vibrates at those revs. I have also checked the timing marks and it all lines up.
So the fact that it has a funny vibration in the mid range, is rich and misses a bit made me think maybe this vibration is caused by something mechanical, and the missing is a electrical problem being caused by the vibes.
The engine was rebuilt about 6 months before i bought it, so i decided to take the side cover off last night to make sure the balancers marks all lined up and they were fine too. While in there i noticed the timing chain moved quite a bit when you push on it.
So my question is can a loose timing change have such a dramatic effect at only one point in the rev range, and could the looseness of the chaincontribute to putting the timing out so much that it will have complete misses?
