I just want to confirm what I am doing is right.....
I have a 2000, XR400.
I put a Unifilter in and removed the airbox snorkel.
I have removed the baffle inside my muffler, and I have a high-flow muffler tip which users the turbine style spark arrestor (which is an awesome idea, as this has a big 2-3 inch hole with NO screening . The turbine flow catches the sparks instead of a screen, which allows tons of flow).
I have aslo heard about grinding down the welding beads inside of the header pipes to increase flow there as well, and I definitely plan on doing this too.
So....I figure that my 400 will be breathing pretty darn good w/ these mods.
Now for the jetting, to make sure I'm not runnin too lean.....
I have heard from some people that a 60 pilot and a 160 main jet are the sizes to use for this setup. (FMF website even recommends 62/162 with their pipes and snorkel removed).
BUT, a few other people have told me that 160 main sounds really big. Too big. A guy I talked to at a race this weekend only went to 145 main with nearly the same setup as mine.....
I ride in Texas, and it's HOT here in the summer, making me run richer, right? Should I go smaller in the summer? What size?
I will definitely be checking my plugs when I re-do the jetting to check myself, but I just wanted some input from you guys as to your first hand experience w/ your trials and tribulations.
1) Is 60/160 too rich for my setup right now? If so, what are you guys runnin?
2) Should I expect 60/160 to really change/ get too rich in the summer months? If so, how what sizes should I go to.
3) I hear the 60 pilot will help w/ starting. What have any of you guys noticed that have gone to a 60 pilot?
Thanks very much for your input.....
Josh:think
Josh:think
