LBRaptor
69
whats the fatest tire i can stick on my stock excel rim and in between my swing arm? i have a ktm 2007 ktm xcw 200 and need a new rear. so i was wondering what size you guys recommend. I want to run the maxxis ITs and was thinking a 120 maybe 130? THis is proabaly a newb question but i honestly dont know the answer.
agitt73
1,078
ive ran the s-12 in 130's on my 02 with no problem
im curently running kenda milleville 120 on my rear of my 02 and 08
ok now here is something i experanced on my kdx 200 i kept running
s-12 130s a couple of tires then a third tire i received by accedent
a s-12 110/100 and i had more traction with that tire then the wider 1's
sloopy
181
yep alot of times the skinnier tires do get better traction in certain situations they dig in better. i think that the tire compound is a bigger issue on hooking up than size though. just my 2 cents
tyler_43
126
depends what kinda terrain you are riding on... on my yz125 i run a 110-90-19 soft terrain and on the rocky trails i prefer a DOT approved (hard compound) 100-90-19. The 200 has an 18inch back rim if i'm correct... so you're tires would probably be 100 series (the middle number is 100 instead of 90).
Fred T
5,272
I always believe that if you put too much tire on the samller dispacement bikes then you have a harder time breaking it loose consistently in corners to turn with the rear tire a bit. It takes much more clutch abuse in situations where you need to get the power back up too. a 100 size tires is usually best but never bigger than a 110. JMHO. :cool:
