o.k. more dumb questions, maybe I'm just confused here or have missed out on something so I'll go ahead and open the can of worms. On what planet do they use ATF or Motor oil in bike trannys? If you had a 68 camaro with a 4 speed manual, would you be comfortable putting ATF in the tranny? How about 10-30 in there? If you only wanted it to last for about 3 miles maybe you would! Just changed the origional tranny oil on my 01 and will tell you, that aint no 10-30 or ATF they got in there! THAT BE GEAR OIL IN THERE!!! So why is Kawi recommending 10-30 or 10-40? Are they hoping you will be coming back sooner for parts? ATF is a very light oil and a type of hydraulic fluid made for automatic transmissions (my kdx came with a manual, how about yours?) motor oil is for 4 cycle engines, it goes in the crankcase, and gear oil is for what? GEARS!! THAT'S RIGHT!! (at least that's what I've heard) If you have had no problems using ATF or 10-30 good for you but I'll stick to gear oil thanks. Throw me some rebuttals here!!
