HOTRODKY428
39
I PAID ATTENTION TO THE TRUING SPECS....I AM USED TO DOING .0001 AXIAL AND .0002 RADIAL...BUT DO YOU GO BY 3 POINTS OF AXIS..OR WHAT ANY HELP WILL BE APPRECIATED.. THANKS ROB
KDXFreestyle
645
I have heard that you can take the wheel off, and take ou tthe axle. Nexxt , use a pencil or somthing like that and stick it through. Take something like 2 milk crates at the same height. The pencil, or whetever you used, put on here, so u can spin the wheel. if you spin it and it moves tot he left, then tighten the right spokes. same for the other side. this is what peopl ehave told me, to get all of the spokes evenly tightened, and to true the wheel. Hope this helps
HOTRODKY428
39
THANKS GUYS...MATT THE LINK HELPED I WAS GONNA TRUE IT IN THE SWING ARM ANY WAY....I FIGURED IF IT RAN THERE IT WOULD BE AS GOOD AS YOU CAN GET IT...THANKS ALOT
