timberguy
For cam bearing caps (KLR650)?
Regular red (27100) good to 300 degrees.
Permatex says heat to 450 for removal.
or
High-temp red (24026 / 27200) good to 450 degrees.
Permatex says to heat to 500 for removal.
I don't recall ever having to actually apply heat to remove the regular red type. Will if actually be necessary to use heat to remove the high-temperature kind? The upper limit of 300 degrees for the regular type seems marginal - not sure what the oil temperature typically runs in a KLR650.
I'm tempted to use the high temperature product if I can find it, but I'd prefer not to actually need to use heat to remove it.
Comments? Advice?
Thanks,
Timberguy
Jaybird
Apprentice Goon
6,449
Charlestown, IN
I never use red loctite of any grade on any part of a bike. Blue only.
